Computers & Internet Logo
Posted on Feb 24, 2016
How do i fix a computer laptop rebooting automatically before its desktop display.
The system is always restart before it is completed it booting process. The system is running window XP service pack 2.
Hp pavillion dv9000 after hitting power button it turns off then on off then on
In case of infinite reboot
- Restart your computer
Wait for your BIOS to display the manufacturer logo or any logo
- T
ap "F8" key immediately: you will reach a list of boot options
Select "Disable automatic restart on system failure
Press "Enter" and wait for your PC to boot.
Acer aspire 1690 laptop can't complete the booting process and restarts automatically. During the booting process, it shows XP windows but can not boot to the desktop and shows a blue screen but the...
blue screen in XP is usually due to hardware issues. Did you add or change hardware? By now, probably your only solution is to repair windows XP by putting in the XP setup disk and get to repair. If you do the install, it will format your hard drive and you will lose your programs and files.
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
After format completes cp gets restart and occur file:\boot\bcd status:0xc000000e
All credit to J W Stuart
"How to repair and reboot to Windows 7:
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the display.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
Note: Please perform step j as detailed, startup repair must be run multiple times.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'. This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer."
Dell d531 diagnostics run at every reboot
What Diagnostics? Is this before the system completes the boot process or is this after windows has booted up and the desktop with icons appears?
2answers
My computer msi brand is automatically restarting and some problem are appear but i cant read becouse it is continusly restarting...i rem the time when im not in my mood and keep badtrip to my computer so...
You have two options to remedy the problem. You really need to access the computer in Safe Mode and view the System Logs to determine the offending piece of hardware or software or virus. But your real question is how to stop the reboot. Use the F8 Key during boot. Right after you turn the computer on, start hitting the F8 Key. The Windows Boot MEnu will appear. at this point you can do one of two things to try to fix the problem. You can enter the computer in Safe Mode which load Windows with only the minimal necessary hardware and software drivers.If you want to see the error message, choose option 8 which tells the computer not to automatically restart after an error. This will enable you to determine the error message on the screen and prevent the system from just going through an endless loop of starting, erroring-out and restarting..
F8 (during boot) Holding F8 when booting displays the Windows Boot Menu
SHIFT (during boot) Holding SHIFT down when booting forces Windows into Safe Mode
Let me know if I can be of any other assistance to you
1helpful
2answers
What is the word rebooting?
Depends on how it's used.
1) "Boot your computer up", may refer to simply turning the computer on.
2) "Reboot your computer", may refer to turning the computer completely off, waiting 20 seconds, then turning the computer back on.
3) The Windows operating system has a Boot Record, which is located on a Boot Sector on one of the Platters in the Harddrive.
These are the basic Windows files.
The computer can also be booted off of another source than the Harddrive.
It can be booted off of a Floppy Drive disk, USB thumb drive, CD disk, or from the internet, to name a few sources.
Therefore it can also mean to reboot off of one of the above sources, instead of the Harddrive.
1) http://en.wikipedia.org/wiki/Booting
2) http://computer.howstuffworks.com/hard-disk.htm
3) http://computer.howstuffworks.com/bios2.htm
1helpful
How do I completly reboot my hp pavilon dv6700 back to is factory settings. I have windows vista service pack2
here are some directions:
(if applicable) When the notebook is powered on, press the wireless button to turn ON the wireless switch.
Turn the power off and on to restart the computer.
Press the f11 key to launch the HP Recovery Manager. NOTE: If the HP Recovery Manager cannot access the hard drive to fix the system errors, use the personal recovery discs to recover the hard drive to its original condition.
When the Welcome to HP Recovery Manager windows displays, click Next .
When prompted to perform a Microsoft System Restore , select No , and then click Next .
When prompted to perform a System Recovery , select Yes , and then click Next .
When prompted to Backup Files , select the desired option.
When prompted to perform a Recover your computer to original factory condition , select Next and
allow the system recovery process to complete. NOTE: Do not interrupt the recovery process even
if the Windows desktop is displayed. The computer will restart automatically during the setup. Wait until the setup is complete and a prompt is displayed to login to the computer.
-http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859585&cc=us&lc=en&dlc=en&product=3636595
2answers
How do I restart my computer from the hard drive do I press ALT and F10 or can you tell me how to set up from a XP pro boot disc
if you want to boot setup from xp pro boot disc, you have to go first to the bios/cmos setup of your system, from there check the boot order, if you find that the first boot device is your hard drive change it, make your cd/dvd rom your first boot device and second your hard drive save the setting that you have made and restart your pc, before you restart insert the installation disc, then reboot, from there it will automatically boot in the xp pro set up disc
When booting up the system, it freezes up
First of all you must turn on your computer. Then follow the steps are given below,
1.When system is booting you can see some screens appear ( bios screens). After the first display finished please hit F8 key on your keyboard.
3.Select Safe Mode & press enter. Some dos screens may appear. Windows Safe Mode is now starting.
4.When the user selection screen appears please select administrator account & login.
5.When desktop loads completely you can see start button.
6.Press start button --> All programs --> Accessories --> System Tools --> System Restore.
7.When the system restore wizard appears you can restore you computer to an earlier time.
8.Select a proper restore point before you install that AVG 8.5. Then select and restore you want.
9.An automatic process will start. When that process completes system will reboot automatically.
10.When System is rebooting don't hit F8 again, Please allow normal booting. Please login your user account & check your problem is fixed or not. If fixed you can install another antivirus program.
best regards,
Krishan.
(Please Vote for me)
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
