Dyson DC25 All Floors Bagless Upright Vacuum Logo
Jayne King Posted on Feb 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The front of the hover wont drop down when bar is pressed
  • Official Brand Answer 2,572 Answers
  • Posted on Mar 01, 2016
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1770463
Points
6009
Hi there Jayne, it's Jack at Dyson.
From what you've described, it sounds like there may be an issue with the locking arm that holds your DC25's cleaner head in place when the machine is upright. This should retract when you recline the vacuum, but doesn't sound like it's doing so in your case.
We'd be happy to provide further advice on this, and if a repair is needed we can provide further details on this. We'd also be able to confirm whether any repairs needed are covered under your free Dyson parts and labour guarantee.
When you have your DC25 easily to hand, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Miele hover the lead seems to be stuck and wont go in when the button is pressed
Usually. Pull the cord a bit further out, gently , if it will come out more, then press button. If it wont come out more, it needs to go to a Miele agent to be fixed
The lead on my miele hover wont go back in when you press the button ialso dont think it is out fully
This might be the spring that retracts the cord. See if you can pull it out any farther. If not then the cord could be out of the guides or the cord is wrapped on the pulley wrong. If you can pull it out and it wont retract at all, the spring is loose or broken.
1helpful
Hello! Help!! The brushbar on my dyson ball vaccuum will not spin. I took out the brushbar and cleaned it, then reset and cleaned out the filters too but still doesn't work. Do you think I need a new...
Sorry this is not a solution. But after reading your problem and other people with the same problem, i just wanted to say i have a Dyson DC24 ball and have only had it 1 year and the exact same thing has happend it is spotless inside and out including the pipes and brush bar, still no matter how many times i press the reset button it still wont spin. I am going to go back to a Hover because im fed up with this piece of **** Dyson! sorry but wasnt there a time when things where built to last! I am now using an ancient Hover junior which is the spare vacume cleaner we keep in the cupboard. Dyson LOL.
7helpful
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
1helpful
2answers
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
2answers
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Can't lower beater bar - so won't pick up lint
the small tube under the hover goes stiff and the beater bar wont go lower enough so youve got to get small tube under hover soft and than set beaterbar to the ground let it go hard and may solve your problem many thanks nick...
F7220900 Hover Steam Va
Go here http://vacuumsuperstore.com/F7205900parts.html
There is a parts breakdown and you can order parts thru them.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
