Question about Pyramid Computers & Internet
If a pyramid of.base B has itd vertex at any point in a plane parallel to and distant h from thr plane of the base,find its volume.
  • Pyramid Master
  • 8,081 Answers
The volume is one third the product of the area of the base times the height or (1/3)B*h
Posted on Apr 01, 2016
SOURCE:
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Mar 29, 2014 | Office Equipment & Supplies
Pyramid tutorials
Good question, and I cannot answer it... but my first thought is, it is not a perfect pyramid. But, if it were, and I wanted to figure it out, I would do a Google search for volume of a pyramid. I'm sure there is a formula out there. I got V=(l*w*h)/3. I'm too lazy to get out my calculator and there is no pencil and paper handy. Good question though.
Mar 27, 2014 | Sport & Outdoor - Others
Pyramid problems in solid mensuration
Look at the problem set up on the screen capture below.
If the pyramid is made of homogenous material you need not worry about the mass (what you call weight) since the ratio of the masses is equal to the ratio of the volumes.
Setting the ratio of volume to be 1/2, and using the ratio of the base areas of the pyramids to be (x/h)^2, you end up with
(1/2)=(x/h)^3
Solving for x, you get x=h/(cubic root of 2)
Mar 02, 2014 | Office Equipment & Supplies
Draw the developnent of lateral surface of pentagonal pyramid of base side 30mm and axis height 60mm
You need 5 isosceles triangles with a base of 30 mm. To get the height of the triangles (perpendicular to the 30 mm bases) you need to calculate the apothem of the pentagon (assumed to be regular).
If you cut the pyramid by a plane passing through its apex, the center of the base-pentagon,and the midpoint of one side, the plane figure created by the three points (apex, center, and midpoint) is a right triangle. The legs are the apothem, and the altitude of the pyramid. The hypotenuse is the slant height of the pyramid, and is thus the height of the triangles in the development. pyramid (60 mm) form.
Use the Pythagorean Theorem to find that slant height.
s^2=a^2+h^2.
Nov 11, 2013 | Computers & Internet
Why triangle looks like a pyramid?
A pyramid is made of triangles, and the number of triangles for a particular pyramid base. For a square base pyramid - 4 triangles; pentagonal base - 5 triangles
Sep 26, 2011 | Riverdeep Mighty Math Cosmic Geometry...
Find the equation of the ellipse whose center is at (0,0), one vertex is at (3,0) and one end of minor axis is at(0,2)
find the volume of the largest cylinder with circular base that can be incribed in a cube whose volume is 27cu.in?
Mar 18, 2009 | Computers & Internet
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Nov 15, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Computers & Internet Logo
208 people viewed this question
Top Pyramid Computers & Internet Experts
k24674
Tom Chichester
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
