HP Pavilion DV6500T Notebook Logo
Ramesh Chandra Posted on Feb 22, 2016
Laptop fan constantly runs as soon as the laptop is turned on. how to change it to auto mode
I am running 32 BIT Windows 7. It's BIOS dopes not have fan control option
Suman
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Mar 21, 2016
Suman
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
2123
Points
55
Update the BIOS.. in run box type "msconfig" >> go to "services" tab>> tick on "hide all microsoft services" >> click disable all> apply restart
Can travelmate 2428awxci run windows 7?
Without any hardware upgrades, I'd say no. Below are the minimum requirements to run Win 7. A stock model of your laptop doesn't meet the minimum.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Windows 7 system requirements Microsoft Windows
Will not recognize extra sata hard drive with win 7 lenovo running win 8
need to go to bios and do change settings. ive never done it with two hdd's i just partition and dual boot. os's were win 7 64 bit and win 8 64 bit.
Asus x50sr fan on full constantly
That laptop have no to much space to get the air , and when the cpu get hotter , the cooler starts to go faster and than he make noise to much , watch the cooler , take off the dust , and take care of the cpu .
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
2answers
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
4answers
Backyard soccer won't work on my 64 bit windows laptop.
Are you using Vista or Windows 7?
As far as i remember Backyard soccer is kind of an old game. It likely only works on Windows XP
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Have an ASUS 939 motherboard installed in 2005 with amd 3000+ procecessor got windows 7 installed 32 bit got 3800+ A2 trying to install 64 bit windows 7 and cannot get the 64 bit CD to run I would like to...
first off win 7 is a dvd both 32 bit and 64 bit should be loaded on a dvd drive also you need to go into bios and set (depending which board u have)the board up for hiper and 64 bit some board auto detect
Problem related to bios setup
it doesn't matter. if you are running 32 bit operating ssytem. you can get majority of the hardware drivers.
however, if the operating sytem is 64-bit, you can't run it on a 32-bit machine. that is what determine by the BIOS.
since you have install the sytem and it seems running fine. I would just leave it alone.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
