Vehicle Parts & Accessories Logo
Posted on Feb 22, 2016
My 7111l avital remote will not start my car it just flashes a green light on the remote
Douglas Cude
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 07, 2019
Douglas Cude
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
25341
Points
99
Sounds like battery are remote bad.
4 Related Answers
logosc75
Larry Spears
  • 625 Answers
  • Posted on Feb 25, 2011
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Anonymous
  • 10 Answers
  • Posted on Mar 09, 2011
SOURCE: Had some work done on my 03 Eclipse and now my
im willing to bet your mechanic seen a wire he didnt think belonged there and just cut it (happens all the time with aftermarket electronics)
Anonymous
  • 95 Answers
  • Posted on Mar 03, 2009
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Anonymous
  • Posted on Jan 26, 2011
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
  1. Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
  2. Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
  3. Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
  4. Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
  5. Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
1helpful
2answers
My 7111l avital remote start my car for seconds. After that 2 seconds, engine off.
Since this is not a factory remote start, you will need to find an installer that is local to you, or maybe you can reach out to Avital for assistance. https://www.avital.com/
Just bought honda hrv had an Avital 7111L remote starter in it. The starter starts the car but when I open the door to get in the car shuts off.
Probably done by design to stop a joyrider jumping in and driving off. Contact Avital direct. FWIW, remote starters are a whole lot of trouble. Let me know when you burn out your first starter motor because it does't release, or it locks you out and won't let you start.
Avital RPN 7111L FCC ID EZSDE147111 Remote for starting vehicle only, (no vehicle unlock/lock or trunk release.) Recently had to have a new battery installed, remote start does not work since. Goes through...
Remote Starters have to bypass the anti-theft software. disconnecting the battery, broke the programming. You will need to take it back to the installer.
Car remote Avital RPN 7111L stopped working when I got a oil change. Help please
Have you changed the batteries lately? Some parts stores have a way to test it.
I have no heat when using my remote start. I have an Avital 7111L Any suggestions would be appreciated. Dealer said climate control is fine.
What type vehicle? My buddy's 2012 explorer would not work until he turned rear heat and blower on the night before. at idle it would not circulate through front heater core. We first thought it may of been low coolant but his was not low.
My Avital 7111L starts my car and dies immediately, Never did this before. However I did just put in a new battery.
same here my Auto starter Avital 7111L happened this morning never happen before , just replaced the battery and it happens press the remote start it start right up but shut down after 5-6 second and restart by it own like 3 times , i like the way the gentleman on top comment said you need to drive around at least 15 minutes for it to relearn the system again , my brother Honda CRV 2017 did the same thing after replaced the battery a lot of light show up on the dash but after driving around for 15-20 minutes it go back to normal again hope this help .
Why remote start Avital 7111L cracks many times before to start a Toyota corolla 2017? Do I need open the car first to start it?
i have a chipper and it started giving lot of problems 4 yrs ago, so I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
2answers
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Top Avital Vehicle Parts & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
