Hey Mark, thank you for your submission!
Based off the information you have provided your Frigidaire oven is no longer heating up after it was cleaned. The oven may need to be reset in order to help clear out any miscommunication. In order to reset the oven you would need to flip the household circuit breaker off for at least ten minutes. If the reset does not help clear out your issue I would suggest seeking assistance from a professional technician. You can locate a technician in your area from your manufacturer's website. I hope that this information is helpful. -Matt
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this
problem the sensor needs replacement. If you want to be sure before replacing
the sensor then you can test it with a voltmeter for around 1100ohms....if it
reads more than this then it needs replacement however, if the reading is
around or less then 1100ohms then it is the control board that needs replacement.
Please get back to me if you have any other questions.
Kevin
