LG Home Applaince LG SteamDryer DLGX2802R 7.4 Cu. Ft. Steam Gas Dryer - Wild Cherry Red Logo
M
MICHAEL Posted on Feb 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHY IS MY LG GAS DRYER NOT ADVANCING TO COOL DOWN CYCLE? MY DRYER RUNS DOWN TO 6 MINUTES AND THEN AUTOMATICALLY RESETS ITSELF TO 16 MORE MINUTES TO RUN AND NEVER SHUTS OFF UNLESS I OPEN THE DOOR. IT IS NOT ADVANCING TO THE COOL DOWN CYCLE. CAN YOU TELL ME WHATS WRONG WITH IT? I CHANGED THE MOISTURE SENSOR BUT IT'S STILL DOING THE SAME THING. MY MODEL NUMBER IS DLGX2802R THANKS
Jorgie the appliance guy
Level 3:
Top Expert:
  • LG Home Appl... Master 5,639 Answers
  • Posted on Mar 06, 2016
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522903
Points
32630
Should check ur moister sensor with a meter and check the hi limit and cycling thermostat fuses
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 • LG Dryers
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
No cycle runs longer than 20 minutes and the clothes are still dripping wet when done.
The motor could be overheating and shutting down. Does it stop mid cycle and the timer keep advancing? if so when it stops wait for it to cool down and try starting it again. If it will not start for a few min. then does it is the motor overheating.
2answers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
1helpful
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
LG dryer won't shut off - gets stuck at 6 minutes
Your problem seems to be the timer switch is faulty.
Timer switches are normally non-repairable. You would need to replace the faulty switch
8helpful
2answers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 • Dryers
Heat cycle stops/
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
part nos 694540 and 694539
Runs on cool down for hours
no, you have a problem there somewhere, it either is A. a bad timer not advancing, or B some kind of thermostat somewhere that is not getting satisfied. give me the model number and i can look into it.
3helpful
4answers
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Top LG Home Applaince Dryers Experts
john h
Are you a LG Home Applaince Dryer Expert? Answer questions, earn points and help others
