While trying to print/copy it does nat print but shows***download mode*** usb available
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
The hard reset you are referring is done by unplugging the printer from the main power source and leave it like that for about1o minutes, to allow the circuitry to cool down and reset itself.
If the printer is less than a year old, still covered under manufacturers warranty.
Hope it works.
SOURCE: Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
SOURCE: what does disabling bidirectional support mean
Normal
0
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
USB to Parallel conversion requires translation by XP and Vista's
'hardware interleave' software as well as the USB device manufacturers driver.
The software package just doesn't work well with older peripherals that use
legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT
printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card
adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many
complaints about USB to Parallel or Legacy Serial adapters. Printing
is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista,
and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5
Mbps.
The BJC-80 and the BJC-85 have the same print speed. The
BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps.
Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR
port, the XP print spooler has problems with it, and can hang if printing more
than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only
with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6
than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers,
and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy
Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port
number.
Install the printer manually from the list of printers, and select the
proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the
adapter card driver may reinstall, and assign the next available LPT port,
LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge
within XP or Vista.
Within Vista, set the Canon ISScan software to run in
Windows 98 compatibility mode, to allow use of the TWAIN driver.
SOURCE: Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
SOURCE: Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
