SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
SOURCE: Our Jazzy Select G.T. power
Hi LOCKING/UNLOCKING THE VSI The VSI has a feature that enables you to lock your power chair to prevent unauthorized use. To lock the VSI: 1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep. 2. Release the on/off key. 3. Push the joystick to the full forward position until the VSI beeps. 4. Pull the joystick to the full rearward position until the VSI beeps. 5. Release the joystick. There should be a long beep. 6. The VSI is now locked. To unlock the VSI: 1. Press the on/off key and power on the VSI. The maximum speed/profile
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
indicator should ripple side to side.
Good Luck
mi mobility
SOURCE: My Jazzy select wheelchair does not run
According to the troubleshooting sheet, the parking brakes have a bad connection.
"9 Flashes:
The park brakes have a bad connection. Check the left and right motor connections and
wiring.
Check to make sure that the power chair is
not in freewheel mode."
Pride Mobility Troubleshooting Sheets
