Spark Plugs BR4HS  Plug 10/BX #3322 Logo
L
Larry Howard Posted on Feb 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When to change plugs on 2008 avalon it has over 100 thousand miles on it
Geoff White
Level 3:
  • Master 1,948 Answers
  • Posted on May 11, 2016
Geoff White
Master
Level 3:
Answers
1948
Questions
Helped
387561
Points
7024
About now is the time. If the car is a V6 the intake plenum has to be taken off to get at the rear bank plugs.
carl blood sr
Level 3:
  • Master 846 Answers
carl blood sr
Master
Level 3:
Answers
846
Questions
Helped
349703
Points
2443
Even my kia spectra has 100 ,000 mile plugs, But I change them every 30 to 40 thousand miles to be safe and the engine runs better. God-Bless! If changing the plugs, put in reccomended ones for your vehicle the originals.
Why is my 2008 Toyota Avalon a/c temperature fluctuating?
It will need to be diagnosed as there is not any cut and dry solution for this type of problem. Sorry.
2answers
When should i change plugs on my 2006 mercury monterey
Spark Plugs ---every 3 years on all vehicles, regardless of miles
---- and not over 50,000 miles
2answers
I jusy purchased a 2008 honda accord with no owners manuel.The car has 19,000. miles.The oil life states its at 100%. My question is do I get an oil change?
100% indicates the oil is new, or at least the oil life meter has been reset. It counts down as it gets closer to oil change time.
1helpful
3answers
How often should i change the transmission fluid in my 2008 honda Pilot
you should change the transmission fluid and filter every 30 to 50 thousand miles after you go so far past and try to change it you can risk burning your transmission up hope this helps good luck..
1helpful
Did transmition oil ws for avalon xl 2008 need
transmission services are usually recommended at about 40,000 miles.
3helpful
3answers
What oil to use--2008 gl1800
depends on where you live. if you live in a mild climate 50-90's-- any 10-40w is good. colder weather you ride in just decrease the viscosity of the oil you choose.
Top Ngk Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
