Samsung 60" Series 8 LED HDTV - UN60F8000 Logo
Jeremy Brickhouse Posted on Feb 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can a bad power board in a samsung tv cause flickering in the screen?
Screen is flickering and it has nothing plugged into it. even does it when using the smart features
David Duncan
Level 2:
  • Expert 72 Answers
  • Posted on May 06, 2016
 David Duncan
Expert
Level 2:
Answers
72
Questions
0
Helped
18005
Points
182
It sounds like your lamp is getting ready to go out, but you are also correct in the fact that a bad ballast could also make the lamp flicker. I hope this helps.
3 Related Answers
Anonymous
  • 163 Answers
  • Posted on Aug 07, 2006
SOURCE: Flickering Screen
soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Anonymous
  • 5138 Answers
  • Posted on Feb 25, 2010
SOURCE: i have a samsung hcn4226w no power at all even to power button.
Yes,the STKs can cause set to shut down, call Mats Electronics 1-800-628-1118
STK392-020
james ayers
  • 170 Answers
  • Posted on May 17, 2014
SOURCE: I have Samsung UE55F9000 UHD smart TV bought only two months ago, when switch it on SMART TV screen appears and its shuts off and goes blank completely. Red switch light keeps flickering on and off. A
Check power cord is plugged in all the way.
2answers
Screen flickers on tv and just keeps cycling
If your QN75Q60TBFXZA screen keeps flicking and cycling, it could be caused by a few different issues, even if you already changed out the CPU board:
  1. Check the power cable to ensure that it is securely plugged in and that the outlet is working properly.
  2. Check the cable connections on the back of the TV to ensure that they are all securely plugged in.
  3. Check the power supply to ensure that it is functioning properly. If the power supply is faulty, it can cause the screen to flicker and cycle.
  4. Check the main board to ensure that it is functioning properly. If the main board is faulty, it can cause the screen to flicker and cycle.
  5. Check the power supply cable connection to the main board. If the cable is loose, damaged or not properly connected, it could be causing the issue.
  6. If the problem persists, consider contacting Samsung customer service or a technician for further assistance.
It's important to note that screen flickering and cycling can be caused by a malfunction or damage in the power supply, the main board or even the backlight. It's also important to check that all the connections are secure and that no damage has been made to the cable or the board during the repair process.
1helpful
Samsung un75au8000fxza backlight flickering
HI Ray....unhook the plug going from the power to main board and see if you get backlights when you plug the set in, if you do chances are you have a bad replacement main
Samsung TV Flickering Issue Fix?
I'd look at a bad panel, the defective panel damaged your main, replacing that got it working somewhat but if it's on very long I'm guessing you will damage the main board you replaced. Try unhooking the ribbon connectors one at a time and see if half the picture works ok, if so you definately have a bad panel
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Vizio SV47XVT 47inch Screen flickers and makes popping sound through speakers what do I need to replace.
This is a power supply and/or possibly inverter(s) board bad capacitors. Since the audio is affected it could be both. Be aware that attempting to repair it yourself could cause irreparable damage to your TV.
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
LG 55LD520 picture problem
the problem with these sets (all brands) is it could be any board in the set or even the panel used for the display---
My TV will flicker at times and go completly black for a period. I unplugged everything and let it sit for about 12 hours and the TV worked fine the next day. The following day the TV again flickered and...
The screen flicker than go blank,does it still have power to the tv set?Yes,than this cause only can be causes by only 2 boards in the tv can causes this problems,if tv power still stable for the set.The T-CON board it shorting out and dying for this problems to happen or worst case causes the Main board tv Tuner signal board it dying.The T-CON board the priced it is cheaper and could cause this problems too.Tries change this T-CON board first,see what happen.This board T-CON board sit at the bottom in the middle of the LCD screen panel to decodes pictures pixel before it go onto the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
2answers
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
3answers
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
