SOURCE: lead in the coffee maker
It does contain a small amount of lead inside a copper coil located in the electronics of the machine. This part does not come in contact with the water, heater or any other part that would cause lead contamination of your coffee.
This page has a great write up explaining it:
http://coffeebreak.today.com/2009/04/08/keurig-lead-warning/
SOURCE: keurig B30 won't brew, no blue light comes on
Our problem was a glass cup. Changed cup to opaque cup and it worked ok, (optical sensor ?)
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day. I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
SOURCE: Keurig B30 model -light comes on but it won't brew
Manual is here...
http://www.keurig.com/help/B30mini_useandcare.pdf?mscsid=4ERVGRF0CN779GJL8ESKBA7FFP6TDX5B
Is the mug clear? It wont like clear glass mugs. or cannt sense offset mugs...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Testimonial: "Yes! It was a blue glass mug and that WAS the problem."
SOURCE: keurig b30 won't brew
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker. 5. Power on machine. 6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage 7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on. 8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours. 9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless. 10. Set Auto-OFF, if preferred.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
