you can do it but that bass cannon will not power the sub well at all. They put out maybe 40 watts RMS. best to find a cheep receiver and do it that way a lot less hassle. better sound. If you dont understand give me a shout.
Sub-woofers work on a low hertz as per audio. You have a built-in amp that has a crossover that separates frequencies under 100 Hz. Typical Hertz range is between 20-60. Since you have a built-in amp the black rectangle is a heat sink which helps to dissipate heat away from the internal components and also seconds as a cover to keep debris and other foreign objects from getting to the amp and burning it out.
the shown photo is a bit confusing too me , clearly this is an automotive speaker , but in the photo there is clearly a home power cord shown , is this power cord connected anywhere on this speaker ? as if it is , id be afraid that amp has received home power and not car power , as the two are not the same and have tremendous differences and would be quite damaging to this amp possibly unrepairable damage
You have a case of a blown sub. You will need a recone kit. You ca send it in to a company like fix my speaker or google recone kits for Power Acoustik FUBAR. May be cheaper just to get another sub.
before you do that i would recommend seeing if you can send it in under warranty because i know that a lot of speakers when you dissemble them you end up doing more damage then good.
