Question about Epson Stylus CX3200 All-In-One InkJet Printer
How do I clean inside scanner glass - Epson Stylus CX3200 All-In-One InkJet Printer
3 Suggested Answers
SOURCE:
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
SOURCE: The inside of the glass needs to be cleaned. How
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
Posted on Oct 16, 2012
Scanner not reading as clear
Is the glass clean, you may need to open the scanner and clean the inside of the glass if condensation has got inside
Aug 30, 2010 | Fujitsu fi-5220C Flatbed Scanner
Tip
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
on Feb 15, 2009 | HP Scanjet G4050 Flatbed Scanner
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Sep 29, 2009 | Epson Perfection 3170 Flatbed Scanner
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How do you clean the INSIDE of the scanner GLASS???
The service manual is avalable free through Emule:
ed2k://|file|Canon%20PIXMA%20MP750%20MP780%20service%20manual.pdf|1416152|F054D74C11BE5EEAF2F6D203362303DE|/
Dec 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Smudges on scanner glass inside unit
hi im jules_09,the scanner glas should not be remove from the unit because if it is remove you might get a error code,so just get a soft cloth or a any kind of tissue and table tissue will do then apply a glass  cleaner on it then gently rob it on the scanner glass until the glass is clean just make sure the unit is off and ulplug.if the scanner glass is cleaned
Oct 13, 2007 | Office Equipment & Supplies
Epson Stylus CX3200 All-In-One InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
