How can I fix a broken scoreboard on a Classroom Jeopardy (#8000)?
My scoreboard works, but one of the gels is damaged and you can't read the numbers on the score. Where can I get a used (main) scoreboard (NOT the add-on). All I need is the score gels. Or, where can I get mine repaired?
If the glass or which is referred to the crystal is broken a repair from a professional is needed. The gasket that the crystal fits into may be damaged and if it is held in with a variety of adhesives this can be challenging as well. If the actual screen is damaged where the liquid quartz numbers have been compromised then it is a factory job and would have to go to the factory.
Decide whether the risk of possibly damaging the watch is worth attempting a do-it-yourself fix. If the watch is expensive, you may want to have a professional repair it rather than risk damaging the watch or invalidating the manufacturer's warranty.
Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
Step 2
Step 3
Step 4
Step 5
Step 6
