If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I HAVE A DELL MONOTOR WITH, TODAY I TURNED IT ON AND IT HAS A 2 INCH YELLOW LINE GOING VERTICAL ON THE LEFT SIDE OF THE SCREEN ...WHAT CAN I DO TO POSSABLY FIX THIS ISSUE?
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
I would try to update the drivers for the display adapters, to do this, go to start>control panel>system>hardware(tab)>device manager>display adapters and select the appropriate adapter and double click it and go to the driver tab and update driver. If this doesn't work, go to device manager and try updating the drivers to the Monitors.....same thing.
the line is a bad LCD panel - some has connections that can be cleaned but not yours
here is the part# 335-26003-00 cost$1,749.95 sounds like time for a new tv
sorry
scott
·http://esupport.sony.com/perl/news-item.pl?news_id=24 ·Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
