Gateway (4000274) Motherboard Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mother board problem
I have a gateway laptop and a while back i went to turn it on and it wouldnt turn on ..i took it apart and on the mother board there is a transistor that was completely blown off the board ..i traced the circuit and it looks like it controls on/off power to the mother board from the battery. I wanted to change the transistor but because it was blown off the board i dont know the number on it . is there somewhere i can get info on this ? why can i find another mother board??. I have all the numbers from the motherboard. I also believe that the battery was the initial probly or possibly the charging circuit
Anonymous
Level 3:
  • Master 721 Answers
  • Posted on Jul 16, 2009
Anonymous
Master
Level 3:
Answers
721
Questions
Helped
257707
Points
1985
Go to ebay,if it's not there....you may be out of luck. Did you try gateway? I didn't look it up but they may still service that board.
Tv went pop, red light came on . wouldnt turn back on but next day sound and no picture. what bulb do i replace it with
There is a lamp in the back which could be the problem or if not that,the mother board.
My computer powers up then immediately shuts off. My mother board Abit IN9x-Max32 sits at code 99. Help??!!
I'd like you to take a Close L@@K at the Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Post back in a Comment after your inspection.
Do NOT forget to use Anti-Static Procedures.
Regards,
joecoolvette
2answers
Bad motherboard or power supply which fries motherboard
Gateway hasn't had any recalls on it that I know of. maybe it is not the mother board. It might be the hard drive. Hard drives can do that aswell. When I fix a computer the first thing I check is the hard drive. A little bit of advice with computers. Start with the small things first and work Your way up to the big stuff. Hope that helps.
1helpful
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Mother Board Gateway MX6958
In order to help you I will need you to take the laptop completley apart and get the model number off the bottom of the motherboard. it will say either intel than numbers and letter or asus than numbers or letters. but we need the model number of your motherboard so we can get you the part number. Or can you give me the serial number off the bottom of the laptop and i can try to look up your information that way and get you the information you need to get the board.
Broil wont COME on
doble check the unit wiring, might have a wire out of place
it the display is showing the broil element on then check and see if you have proper voltage at the element, work bat to the board and find the problem
Wont turn on
All PSU's have a RED switch on the back make sure it is set to 115V. Connecting the case back to the mobo is described in the manual. If you do not have the manual you can connect with Gatway through online chat at: http://support.gateway.com/support/contact/chat.shtml
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
