SOURCE: Won't Print Quicken Checks- Canon MP620
Here is all I could find, as it is a compatiblity issue and not a repair issue. Hope this helps. You can also get on an online instant chat at www.hp.com and they may also have some answers for you.
HP has apparently released new printer drivers for some of their
> printers that will fix at least one print problem experienced by
> Quicken users.
> If you have an HP printer and are having problems printing from
> Quicken and you use 64 bit Vista, check this HP faq to see if there
> may be help for you.
> http://tinyurl.com/89ly3u
P.S. It appears that the fix will apply to more printers than are named in
the faq; The way I understand it, if there is a version 12 driver available
for your printer model, you probably should get it.
Apparently the list of printers to which the fix applies will be updated at
some point.
Don't forget to rate this 4 stars before you log out. If I can be of any help let me know.
SOURCE: Canon MP620 Wireless All-In-One can't print to it
Hi
I had exactly the same problem. Here is how I solved it.
I deleted all the previously installed items (although this might not actually be necessary). Then I re-installed using the 'Easy Instal' option from the CD.
The CRUCIAL part is this: - after you have tested your connection to the printer - and it is all fine - another box should appear with a MAC address for the Scan Twain. Highlight the string of numbers and click APPLY.
THEN THE MOST IMPORTANT BIT - look at page 54 in the set-up guide. And follow the instructions which are:
When the printer utility opens click ADD - then go to 'more printers' select the MP620 with the string of numbers after it. This is the one you want NOT the one that appears automatically when you complete the installation.
make this printer your default and away you go! That should work as it has for me and i have been pulling my hair out on this for about 3 weeks!
SOURCE: set up wireless connection canon mp620
I realize that you posted this question over a month ago...but I'll still give you your answer in case anyone else is also experiencing this.
All you need to do is enter in the correct password...the one you gave your router. Which I realize was probably a while back, and you didn't write it down (tisk tisk), so here's how you find out what you typed, way back when.
open up your internet browser (Internet Explorer, Firefox, Safari, ect...). Now in the search bar type in your routers IP address.
mine is: 192.168.2.1
yours might be the same or might be something similar...like: 192.168.1.1
only type that, and include the dots...no www junk.
once you typed it in, hit enter.
and now you should be in your router...then steps hold true for all routers I believe (mines a belkin).
it will ask for a password, most people simply leave theirs the default password, my password was nothing....literally, I just left it blank and clicked 'next'. yours might be 'admin'...a google search should help you find your routers default password.
Ounce you have the routers password, you have access to change a lot of the routers features...including finding out that pesky passphrase that your in search of.
your welcome.
I accept cash & credit. I'll send you the bill. ;)
SOURCE: instructions to set up my canon mp620 (wifi) to laptop
There's a good video for first time wireless setup of the MP620 at this link. Click on "Frequently Asked Questions", then click on the first question on the list.
SOURCE: i have an envelope stuck inside my canon mp620 pri...
There are three areas for paper jam clearing.
1. Under the scanner cover
2. At the rear of the printer is a small door with rollers at the top. it comes away from the printer from the left. There are some small pins to hold it in on the right. Swing it out to remove the door.
3. The cassette tray. Remove the tray to expose jammed paper or envelopes.
Here is the diagram for the rear door.
Do not touch any components inside the printer.
