Proscan 32LB30QD 32 in. LCD TV Logo
Dawne Kieser Posted on Feb 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red power indicator is on, when try to turn on blue light comes on then shuts down back to red
Level 3:
Top Expert:
  • Proscan Master 76,851 Answers
  • Posted on Feb 16, 2016
Proscan Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005579
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
Comes on and then gose off .
which means the power shuts down as soon as you try to turn it on. disconnect all speakers from this amplifier -then try . if it still shuts down it indicates protection circuit is activating because a channel or two is bad.
5helpful
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
Toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: [email protected] The cost is 375.00 and that includes parts.
Good Luck.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
1helpful
3answers
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
