I've lost the battery so need to know which one to buy to replace
SOURCE: Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
SOURCE: Have a Kenneth Cole watch and the battery needs
Get a flathead screwdriver from eyeglass kit and the back cover will pry off to replace battery
SOURCE: Lost battery for Kenneth Cole watch style 3837.
After very close inspection, I was able to read (with magnification) the worn data on the watch case which had the battery number inscribed.
SOURCE: how to replace the battery in a kenneth cole watch kc3346
I have not figured out how to open the casing lid to replace the battery, but the number for the battery you need should be engraved on the lid. Double check your own lid, but mine says that the battery is an SR621SW. I'm sure there are different brands that would match this number.
