Microwave Ovens Logo
d
deb repsold Posted on Feb 15, 2016
How to replace the led display board... bought the part, need instructions
My Samsung microwave model C139STFC got no display but is working fine
If it is an led display, it might have a display driver integrated circuit that has gone bad. More likely, though the driver might be part of the microprocessor. Either way, you'll either need to have an electronics technician fix it, or replace the circuit board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nn2555 display weak
In many cases , cockroaches are found to habit within specially when not used and can spoil the main board, panel display and connectors. Remove the front panel and board and confirm and if so you need to wash the board and reset. Also it can be due to failure of the display or drive from the board
1helpful
Miele microwave led not working
The keypad control board will need to be replaced, the cost for the part alone is $100.00 or more.
My built in 5 year old microwave AMW 520/IX display has gone wonky. Some of the LEDS stay on no matter what number should be showing.
The display driver is faulty. A replacement display board may still be available. Try www.espares.co.uk or a Philips Microwave dealer.
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
F9 fault. I replaced the main control panel, with the led display. Still F9 fault after 9 sec. Also get a high pitch humming sound at times. Heats most of the time & F9 does not always come up when...
That sounds like a problem on the invertor board. Unfortunately there is not a lot to be done on the board without a service manual and the needed experience.
Hope that helps.
2answers
SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Most of the LED display is inop
Give me the complete model # from the sticker inside the microwave so I can look into this for you.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
