No power to bake element
SOURCE: Dacor model W305 blew an element. Replaced it. Won't work.
The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
It is highly unlikely that the fan and element are faulty, you will have to look further.
Plz rate this solution.
Thanks, and merry xmas.
SOURCE: JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
SOURCE: I have a maytag mer5755qab
It is possible that when the element blew that the control board blew and is what caused the element to blow the chunk out of it. You might want to check for any voltage coming from the control board.
SOURCE: GLEB30T8CSA upper oven baking element has no power
It may be you have a bad element. If you remove it and have a volt meter you could check a the socket for power. Also if the upper and lower elements are the same change the working one to the upper oven and see if it works. If it does you need to purchase a new element. If there is no power to the upper oven you may have a bad control ora broken wire behind the panel. I would advise you to turn off the power to the oven before pulling or changing any componets.
