Computers & Internet Logo
A
Anonymous Posted on Feb 15, 2016
Optiplex 960 number 3 blinking
It blinking number 3. When i remove power cord after 1 minute number 3 blinking gone and computer is starting normally. But this process usually coming often. What i need to do? Change Power block or motherboard
Terry Hair
Level 3:
  • Computers & ... Master 4,134 Answers
  • Posted on Feb 15, 2016
Terry Hair
Level 3:
Answers
4134
Questions
Helped
1090856
Points
16804
The #3 light is an indication of a processor problem. You may have a bad cooling fan, or a poor heatsink connection, or just a failing processor. The fact that it resets makes me think more along the lines of a fan issue. Here is a list of the codes and what they mean:
http://f5k.wikia.com/wiki/Front_Panel_Lights_-_Optiplex_755,_960,_980
De ice
Level 3:
Diehard:
Visited the website for 60 consecutive days.
  • Computers & ... Master 711 Answers
De ice
Level 3:
Diehard:
Answers
711
Questions
Helped
175394
Points
3800
Three means processor or motherboard failure
three with blue screen processor (reseat it)
three with screen off motherboard
3 Related Answers
Anonymous
  • 231 Answers
  • Posted on Sep 22, 2007
SOURCE: Dell Optiplex 160L Motherboard
Hi there is one more thing you should check before buying another mobo. Trace the wires from your on/off switch on the case, unplug it and then bridge the 2 pins out with a screw driver, this will start the computer. runit as normal, then shut down and see if you get a restart. If the computer does not restart on its own you have a faulty switch. Clean it or replace it. Regards mistyman
Anonymous
  • 29 Answers
  • Posted on Apr 02, 2010
SOURCE: OPTIPLEX 960 error codes 1 and 3 at startup
Blinking amber ... seems like an isuue with the power supply .. check if you see the power supply fan spinning at the back of the system tower... If its spinning then you could try reseating the memory modules inside the system tower . Opem the tower and then disconnect the green colour ruler shapped modules which has a latch on either sides. then try turning in the system ... check if turns on properly.
Hope its informative.
Testimonial: "Thank you - computer works with another power supply. You got it, Master!"
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Mar 23, 2013
SOURCE: my optiplex 960 does not turn on
Dell Support > Optiplex 960 > Manuals & Documentation tab > Service Manual (6460KB),
http://www.dell.com/support/troubleshooting/us/en/19/Product/optiplex-960
A) "Light Pattern,
Number 3 - Blinking Amber -
A possible motherboard failure has occurred"
This you must have known........however going on.........
"Number 1 and 3 blinking amber -
A possible motherboard, Power Supply, or peripheral failure has occurred"
The first thing to check with desktop computer failure, is the Power Supply.
If we are to agree that using the motherboard diagnostic LED's, and specifically the No.3 LED was blinking Amber; then we can agree it was motherboard failure in the first place.
However, me? I'm a skeptical computer geek.
I ALWAYS, test the Power Supply's 3 main voltage power rails FIRST, then I may go on to assume diagnoses has led to the motherboard, peripherals, etc.
From there, it's check the Radial Aluminum Electrolytic Capacitors on the motherboard, for visual capacitor failure.
The motherboard chipset going out, is a Rarity.
IF, it does fail; it's usually the Northbridge chip of the motherboard chipset; because it get's the hottest.
(That's why it has an aluminum finned Heatsink on it. Sometimes Southbridge chips do too)
Southbridge chip is next in line.
You don't know how many desktop computers, I have fixed over the years; that the problem was the Power Supply, and not the motherboard, as assumed by the owner.
Also it's all over the internet.
LED's light up, and fans spin; and people assume the Power Supply is OK.
This = No.
1) If ALL of the LED's were lit up at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor (CPU) uses 51 to 130 Watts of power.
Just depends on what Processor it is.
Therefore a Power Supply with a weak voltage power rail, will have PLENTY of power to operate those simpy little Light Emitting Diodes, and maybe spin fans; but will NOT have enough power to turn the Processor on.
Either test the 3 main voltage power rails, with a multimeter set to DC Voltage, (3.3 Volts, 5 Volts, and 12 Volts),
OR,
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psuconnectors/connectors.html
Power Supply deemed to be good? Go on with the diagnoses.
Visually inspect the capacitors on the motherboard,
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
What? Are you cra-zy Joe? Did you not read I replaced the motherboard?
Ahem,
That motherboard you have, IF a direct replacement; is an NOS.
New/Old Stock.
Been sitting on a shelf for years.
Point?
Electrolytic Capacitors break down over time. It's the 'nature of the beast'.
They have Electrolytic Paste inside, which is a chemical.
It's known to break down over time.
Computer engineers know this, and use capacitors that are rated at TWICE what is needed. 200 percent.
So..........when the capacitor breaks down to 50 percent good, it is still 100 percent good for the application.
Point?
New purchase, or not IMHO it could be a bad motherboard.
Another point of interest; Electrolytic Capacitors do NOT always show outside visual signs of failure.
The Electrolytic Paste inside can just dry up, instead of developing a gas, (Hydrogen Gas), and not break the seals of the capacitor.
However, I would make sure the power is good, then disconnect all internal peripherals.
Peripherals are also the Harddrive, as well as the optical drive (CD/DVD drive), and Card Reader or Floppy drive.
(Outside peripherals; Keyboard, Mouse, Monitor, Printer, etc.
Leave Keyboard, Mouse, and Monitor of course; but disconnect any other outside peripheral)
That means disconnect the data cable from Harddrive to motherboard, and power cable to Harddrive.
Also same for optical drive/s.
Disconnect, the two cables from the USB header on the motherboard, for the Card Reader. (media)
Floppy Disk Drive data cable, and power cable, IF used.
LEAVE the front computer case fan connected, as it's cooling for the Processor. Ram Memory is installed also.
(NO graphics card if you have installed one. Connect monitor cable back to the motherboard. {Back of computer > I/O area)
So essentially we are talking just Processor, processor fan, and Ram Memory.
Turn the computer on.
Try to pull the BIOS Setup screen, up.
If no, you have a bad motherboard.
Now remember, this is AFTER the Power Supply has been deemed good.
BIOS Setup screen comes up?
Then reconnect the harddrive.
Good to go?
Then reconnect the optical drive. If drives, connect one at a time.
Check.
Then connect the second optical drive.
Good to go?
Then reconnect the card reader.
Had a post from someone on here not long ago; that we went through diagnosing; until he found out the Card Reader was the problem.
If memory serves it was one of the cables, coming from the card reader.
I'm guessing he ran a continuity test on the cable, with a multimeter set to OHM's, to check whether it was indeed the cable; or the USB header on the motherboard it plugged into.
He never stated.
Arranging all that prattle I stated above.......I mean Summation:
1) Test Power Supply voltage power rails, or use KNOWN to be good, Compatible power supply
2) Visually inspect Capacitors on motherboard.
3) Processor, processor fan, Ram Memory, ONLY; see if you can get BIOS Setup screen to come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
2answers
How do i reboot a dell optiplex 960 to factory settings if i cannot login?
How to enter BIOS?
1. Turn on or restart your computer.
2. Press "F2" to enter "System Settings" (BIOS) when the DELL icon appears.
Restore the BIOS to default settings.
Press "Caps Lock", "Num Lock" and "Scroll Lock" buttons to light up the corresponding lights on the keyboard. Then, press the following three combination keys:
Alt+E - Clear (Release) the interrupted resources and reallocate resources at next startup. After pressing the combination key, you will hear a sharp beep tone.
Alt+F - Restore BIOS to the default settings. After pressing the combination key, you will hear a sharp beep tone.
Alt+B - Restart the system.
Password clearing method 1: When the password input box appears, type in the password and press "Ctrl" and "Enter" simultaneously.
Password clearing method 2: Remove the PSWD jumper on the MB and start up the system. Set the password to empty in BIOS, shut down the system and reconnect the PSWD jumper.
Hope this method will help you otherwise check Dell Optiplex 960 Manual- https://guideusermanual.com/product-name-optiplex-960-manual&po=344822&lang=English for expert's suggestions.
My dell optiplex give a orange light on the start bottom
2007pc NOW 7 YEARS OLD AND COIN CELL DEAD IS #1
op the manual on your PC is free to read and covers power lamp codes. for sure
orange blinks or now
the ornage my mean in sleep mode
I have 755 here is mothballs.
page 153 here (15 seconds to find and read that)
it means power failure .
https://dl.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-755_user's%20guide_en-us.pdf?ref=supp_lithium
NEW COIN CELL
REMOVE ALL AC POWER TO PC FOR 1HOUR. LINE CORD TO WALL. REMOVED
THEN PUT THAT BACK
AND PUSH POWER BUTTON FOR 10 SECONDS.
POWER LED GOES GREEN NOW?
ALL FANS WORK
MONITOR WAKES UP?
I have dell 960 switch it on but light turns to orange
Could be several things.
1. could be the power supply
2. inspect the motherboard for bad caps.
If the above is OK. Try removing and reseating the CPU, Memory and CMOS battery.
The battery led blinking red/green
Disconnect power cord. Please take out the battery. Hold down power button for a minute and then connect only power cord. Restart it again.
1helpful
2answers
My Dell Optiplex 745 Desktop PC Power light orange blinking how can i solved it..
The orange blinking on your desktop power button says that there's a problem with either the power supply or the motherboard itself.
Please refer to this link for the diagnostic lights on dell computers.
What you can do is: 1. unplug the power cord 2. press the power button, hold on it for more than 5 secs 3. re-plug the power cord on your CPU 4. test if it the system will work.
If this troubleshooting step does not help, that means it is more likely that the problem is with the motherboard.
Hope this helps!
Hi - I have a HP Officejet Pro K5400 printer. That printer & my Dell Optiplex GX620 was left on during a 2 week office absence. When I returned the blue ink cartridge indicator light was blinking and...
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
3helpful
2answers
OPTIPLEX 960 error codes 1 and 3 at startup. Both numbers and power button are amber blinking. Doesn't boot. Nothing on screen. Please help auntie.
Dell E521 blinks on and stays powered up but does not start start up sequence can't F12 or anything as it does not get that far
Just had similar problem with optiplex 755. Solved problem by resetting bios. Remove power cord. remove bios reset jumper. (check owners manual or dell website for the location) Dell says to remove for 5 seconds and replace to reset bios. I find this to be incorrect. I had to unplug cord remove jumper, plug cord in, restart, shut down, unplug cord replace jumper, reinsert power cord and restart. Had to change a few configs in bios based on computer configuration after restart. Hope it works for you. Seen same problem on optiplex 750 and 755 in last week.
Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
Grand Canyon Tech
Grand Canyon Tech
