It is also displaying unknown language. and I just want get rid of it for good.
SOURCE: lock code
for your info, nokia default password is 12345. if the code doesnt work, try the method below.
there was a lot of chance if you use LogoManager Pro Suite, this can easily reveal your unlock code.
just install LogoManager Pro Suite and connect you phone by cable (recommended).
bluetooth and IrDa (infrared) doesnt work for me.
LogoManager Pro Suite (demo, but can be used)
http://www.logomanager.co.uk/php/products.php?id=54
if you dont care about to lose your settings, just flash it or format it.
to flash this, please make sure nokia pc suite for your e63 is installed with driver, then
connect the phone to your pc by cable, open the nokia pc suite and backup your stuff.
after that, update/upgrade your phone software (this process using internet connectivity)
when the process finnished, restart your phone (turn it off and turn it on again).
i guarantee that you will get a fresh one with unlock code 12345.
*there was no use if you find the mastercode by using IMEI OR calculating your IMEI by using IMEI calculator
SOURCE: Is it possible to unlock a nokia e63 for free
ya you can contact service provider for puk no and reset the lock code
SOURCE: Security unlock code for Nokia E63. This code is
sir your default security code is 12345 in any nokia handset.
SOURCE: nokia e63 unlock
Unlocking a Nokai E63 SIM phone requires an unlock code which you can usually get for free by calling up your phone carrier and requesting one. In exchange they will want your IMEI number which you can get by typing *#06#. Then you can use these Nokia E63 Unlock Instructions to remove your phones SIM lock to use it with any carrier you want! Good luck and i hope this helps!
