Question about Planar PR2010, PR2020 Projector Lamp - 997-5248-00 - OEM Equivalent
How do I remove lens, spray paint got on the inside of the lens
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Aug 22, 2016
SOURCE:
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Spray can won't spray how to fix
Pull the nozzle straight up and out. Grab a nozzle from another can that looks to be the same and try that one. You may have to try multiple nozzles. You can also buy nozzles on ebay, but they are usually more than the price of the can.
If this doesn't work, then the can may be faulty, or if very old (many years) it may no longer have pressure even though there's still paint inside.
Another thing to check is if the ball inside rattles when you shake the can. If it doesn't, the paint might be hardened in the can.
Remember next time you finish painting to wipe off the nozzle, turn the can upside down and spray until almost no more paint is seen.
Sep 27, 2016 | Rustoleum Rust-Oleum - 1685830 - Spray...
Remove Spray Paint Over Spray on Vehicle
Could try grim and wax remover/prep for auto bodies. Auto stores have it. Then polish/ wax the spot.
Mar 21, 2014 | 2004 Dodge Ram Pickup 1500
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Clean paint spots off black refrigerator
no...actone is very caustic and can damage the paint. i believe it is illegal outside an industrial use in california. use a paint thinner. the paint job should be falme sprayed or powder caoated. if its house paint a good soap and water scrubbing should work too.
Jun 25, 2008 | Maytag MFI2568AE Side by Side French Door...
How to remove spray paint from iron?
Try using WD-40 - no kidding! It works wonders for removing spray paint depending on the type and how long it's been on.
Mar 18, 2008 | Coffee Makers & Espresso Machines
Planar PR2010, PR2020 Projector Lamp - 997-5248-00 - OEM Equivalent Logo
551 people viewed this question
Top Planar Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Planar Office Equipment and Supply Expert? Answer questions, earn points and help others
