Curtis Klu 7-inch Touch Screen Mobile Internet Device Logo
s
sierra hafer Posted on Feb 15, 2016
Screen cracked inside
How do i fix a screen that cracked on the inside? I can't touch my unlock pattern!
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
RCA Android tablet. It has a crack across the screen. How do I unlock it? its got a pattern lock on it?
As far as I am aware you will have set the pattern lock.. It's usually a four digit code that you need to input by sliding your finger across a digital pad WITHOUT removing the finger from the pad until you've finished. If you can't remember the code try some possibles, remembering that you probably have a limited number of attempts before itr locks up you could also try settings on the android.
2answers
Unlock cracked screen nextbook 8
On some touch screen device, the tough part of the screen won't work when it has a crack. So it ill be difficult to unlock the screen as long as it has a crack. Ask yourself if it is worth repairing the screen, when you know what a repair shop asks for the repair and what a new device costs.
Success
2answers
Locked out of my Kids Tablet 7 inch touch screen Android 4.1
You did try to hold vol+ while powering on, and keep on holding vol+ until you get the menu?
Cracked screen on my Trio tablet, can see the display but it won't respond to touch. It's not under warranty. Can I fix it myself?
Yes touch screens are very sensetive.Because of the cracks on the screen ,the board can't read the command.The screen can be replaced only if you know what you doing however it can cost upto and around between $250 and $350 mark to repair by a professional.to get better ideas of what your up for research on Utube .
2answers
Patten lock unlock
what Is the problem, do you drew the wrong pattern many times?
or do you forget the pattern. if so,
guess 5 patterns if every patterns are wrong you will see a option forget pattern, click it
then you can give your email id. then you will get the pattern through email
8helpful
2answers
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Top Curtis Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
