Maytag MFI2568AE Side by Side French Door Refrigerator Logo
Posted on Nov 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ICE/WATER DESPENSER PROBLEM
I purchased a Maytag H20 fridge just 14 months ago for 2500 and now the darned thing is on the fritz. The water/ice dispenser is wildly lighting up and continuously opening and closing. The thing is possessed. I'm reading the same problem with other people is occurring. Is there any recourse? I bought this thing  thinking I was buying the best and it was going to last a long time. It sounds like there is a manufacturer flaw thats occurring just after the warranty is expiring and the owner is sol. This is not right and Maytag or whoever is there parent company should make it right. Do I eat the cost of repair or should I just buy a replacement.
  • LASTSTRAW Nov 19, 2007
    I got a hold of Maytag and there seems to be a recall on the fridge. Thanks fridgetech!
Anonymous
Level 3:
  • Master 473 Answers
  • Posted on Nov 17, 2007
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451932
Points
1483
The control board on the back of the fridge needs to be replaced. Call the customer service # in your manual. They have been making concessions for this problem.
1helpful
Water/ ice issue
this problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
1helpful
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
1helpful
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
1helpful
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
1helpful
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
