Blue tooth by definition should be able to connect between any units that are Blue tooth capable. Make sure the Blue tooth is turned on on both units and both can be identified.
have you looked in the owner's manual ? Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
If your TV is bluetooth enabled, yes the same as your phone or other device.
If your TV is not bluetooth enabled, yes, but only with the auxiliary cable that came with your PBT 3001. The back of your TV should have a coaxial audio out (a solitary orange audio output). Depending on your model TV, you may have to get an adapter to be able to use this output.
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
Blue tooth capabilities requires hardware chip and programming.
If your tablet does not have built in blue tooth, then the answer would be a negative. If tablet is blue tooth capable, the blue tooth device must be capable to mate to tablet blue tooth version technology.
