You will get Original Victorian Pine Floorboards online at The Reclaimed Flooring Co, here you will find Original Victorian Pine Floorboards and Edwardian pine floorboards which have become increasingly difficult to source in recently years. Get them to your living room floorboard today! Original Victorian Pine Floorboards The Reclaimed Flooring Company
I am not a mechanic.. but from experience with other vehicles... if battery cable is corroded or loose,, battery weak,, it causes the computer to mess up... Here is something else to try.. I changed my battery in my van also my sons truck.... started them up and they would not idle.. mechanic friend of mine said to do this to reset the throttle body senser..."" Do not start, but turn key to On.. Press the gas pedal to floorboard 3 times,,(not real fast) then turn switch to Off... now start the car as normal.. It works on Dodges I know.. Good luck
It is flooded. Sometimes difficult to start afterward
if this is the case you have to floorboard the gas pedal - which floods the carb more so and keep it there for two minutes. Then try starting it. If and when it starts - ease off the gas or blow the engine.
Fuel injected vehicles can be very unforgiving when they run out of gas. Add as much fuel to the tank as the situation allows and then get some one to give you a boost. While cranking the engine hold the gas pedal to the floor and keep it there until (hopefully) it starts. Do not pump the pedal. Just keep it pressed to the floorboards. It should fire up. Crank engine for about 30 second intervals and then let it rest about a minute before trying again. That way you will not burn up the starter.
Hi, Start your Volvo up push you break pedal down, shut your Volvo off with the break pedal down. If the booster is good the pedal should NOT go towards the floor board. It should hold in place. If the pedal moves towards the floorboard the booster is leaking. Wayne
I have floorboards on my 02 WG - both rider and passenger. The passenger boards are HD. The rider boards are these: (about half way down the page - Adjustable Floorboard Kit - part number is CS190505)
http://www.cas4.com/Forward-Controls...oorboards.html
Easy install - remove the footpeg, bolt the floorboards in place.
I'll see if I can find some good pics of my bike with the floorboards installed.
