Motorola Mobility RAZR V3 Logo
Peter Flynn Posted on Feb 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Took the blue light out from the bottom front ;now it wont ring;it vibrates but no rng
  • Official Brand Answer 1,623 Answers
  • Posted on Feb 23, 2016
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350398
Points
5677
You can try doing a factory data reset (FDR), you can follow this steps https://motorola-global-en-usa.custhelp.com/app/answers/detail/a_id/66826
Best regards,
Marvin.
Motorola support
My phone got wet.. I dried it out and now it wont stop vibrating. it start to vibrate right when the battey is put back in.. Even when its off it vibrates. i took it apart to see if i could disconnect it...
You have a bad ********. To remove it, the ******** looks like a little motor with half a cylinder metal piece sticking out. You can cut the wires on it and it wont affect your cell phone, if they exist. Otherwise it's probably in a rubber casing with two spring looking leads sticking out of it. You can just pop it out of the blue casing.
Jun 16, 2011 • Cell Phones
tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
1helpful
My htc hd2 wont ring or vibrate even after i have did a factory reset
go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
that should do it ;.)
3helpful
1helpful
My sansa wont turn on, I took out battery to reset and blue ring
Try resetting your firmware via Sandisk's support site. If it still doesn't work, your sansa's mainboard might be busted. The cost of replacing it will be more than a refurbished one (under $40 online).
12helpful
3answers
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
Speaker phone wont work
Firstly, you need to check your profile settings for the phone. You can do this from the homescreen it is the megaphone icon.
Scroll to the bottom for advanced, and then edit the active profile - From the list opt for phone and check both in and out of holster settings - Which should be ring & Vibrate for phone.
Let me know how you get on with that.
Pantech c3oo wont ring
It is in vibrate mode...it drove me crazy too!
Simply press and hold the "*" key at the lower left to exit vibrate mode.
3helpful
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
