It sewed good for a few minutes and then seized up. I cant turn the manual wheel. I tried to oil it and look inside for anything that might be jamming it, I found nothing. Could a bad needle be the problem?
Probably not a needle as they just bend or break
the main fault for jamming the machine is cotton that wraps around the shaft behind the bobbin carrier
basically it needs to be checked over by a service mechanic so there may be a seized bearing on a shaft
Testimonial: "Thankyou for your advice. I will check the bobbin for lint or old threads. If that don,t work I will take it to a shop and have it looked at. Thanks again."
