KDF 60XS955 intermittently turns off green light blinking then on after...
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state
ref:
Sharp lcd tv power button flashing
SOURCE: Blinking Green Light
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: model hln617w. the picture on the screen freezes
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
SYMPTOMS:
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
SOURCE: tv turns on and works but out of nowhere the
Hi
It is symptom of dying lamp in tv, replace it to solve tv issue.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
