How can I silence the signal noises? I want to completely turn off the bells and buzzes that sound when I turn the dryer on, when it ends its cycle, etc. How do I turn them off?
This dryer makes noises for every setting I select. It is annoying and too loud next to the baby's nursery!
To permanently silence the end of cycle alarm on your Bosch Vision 500 Dryer, check there will be a signal button on the control panel. Just push thet button.
Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Feb 12, 2007 - 10 posts - 1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
More of the lint and mouse junk may have moved up closer to the dryer wall. Take the dryer hvent hose off the dryer to see if there is more stuff in it. Sound like the tub cannot move.
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
