Wow... I hate REFERRING ANYONE to SEARS ($$$$)...
but they pop up very prominently for Lasko parts... and their support library is pretty good...
So... (top link at the bottom)
1-800-252-1698
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
Always get three estimates...
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
repairclinic.com
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
easyapplianceparts.com
Find Your Appliance Parts
SOURCE: Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
SOURCE: Hi, we have a Lasko 6350 oscillating ceramic
Blow the dirt off the filter in the back... then shut it down for 5 min. it should then work..
SOURCE: Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
SOURCE: Portable Heater keeps turning off
I just fixed my Stanley Lasko 675900
FOR GOOD and would like to tell the world how to fix it! I hope this work for you and good luck!
1. Remove the front plastic grill.
The bolts are torx heads with a center pin. You may be able to find a
torx head driver with the center pin but I improvised. I Used a
dremel tool with a small rounded diamond bit to grind the center pins
out of each screw so I can use a standard torx head driver on the
screws.
2. Remove the heating element. These should be Phillips
screws.
3. Blow out the dust from the back side of the heating
element. (be careful with the fragile fins)
4. put it all back
together and it should work just fine.
5. (optional at your own
risk!) I believe the small gadget attached to the top of the heating
element with the white wire is the limiter. You can use pliers to
slide the unit out of the element and either move the unit further
toward the center area, or cut the device out completely with wire
cutters and then splice it back together. If you do this REMEMBER TO
CLEAN THE BACK OF TH HEATING ELEMENT EVERY MONTH TO PREVENT A DUST
FIRE!
