Cars & Trucks Logo
Sampson Hamilton Posted on Feb 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One high beam not working 2006 Buick lacrosse
  • Kare Fay Jones Feb 27, 2017
    I have a 2008 3.8l, v6. And I took it to the Buick Dealership, since it was part of a recall, it was free of charge. Call GMC and have your VIN # ready, your Year may be included in the recall.
L Pfaff
Level 3:
Top Expert:
  • Buick Master 11,573 Answers
  • Posted on Feb 13, 2016
L Pfaff
Buick Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587220
Points
181713
Sampson, sounds like a bunt out bulb, which will need changed.
If you feel comfortable doing it yourself. Basically three screws, and you have to pull one plastic fastener from the fascia (bumper) and pull the bumper back a bit, and pull the assembly out. I believe it is in the manual, not bad to do. I will post a link to tell or show you how to do it. Press the helpful button
Headlight Change 2005 2009 Buick LaCrosse 2006 Buick LaCrosse CX 3 8L V6
2008 Buick LaCrosse Headlight Replacement
Thread how do replace the headlight bulb in 2005 buick lacrosse
Headlight Bulbs
Kare Fay Jones
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Feb 27, 2017
Kare Fay Jones
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
835
Points
Call NHTSA, could be part of the Headlight recall.
paulmacintyre
Level 3:
  • Buick Master 3,218 Answers
paulmacintyre
Buick Master
Level 3:
Answers
3218
Questions
0
Helped
968278
Points
11418
The daytime running lights are incorporated within the high beam lighting circuit. If the bulb is not at fault, you may have a daytime running light module/circuit failure
2answers
My low beam lights are out on my 2006 Buick Lacrosse High beams are ok. already replaced relay 35 HDM with no help
Check the fuse box under the hood, a lot of cars have fuses for the head lights. Should be marked on the cover of fuse box.
2006 buick lacrosse low beams not working high beams only is i hold in the turn signal
this sounds like a bad dimmer switch not functioning. I would first check to make sure the rod that runs from the lever to the dimmer switch is traveling the complete length and is not out of adjustment.
Low beam headlight - passenger side - on my 2006 Buick Lacrosse does not work. I've tried a new bulb - no help. The fuse - underhood fuse box - for the low beam is good. There is no voltage to that fuse...
From Info I have looked at I believe under hood micro switch relay 35 is for low beam and 34 is for high beam. It also looks like you have a different fuse for each light. The relay are for both low beam or both high beams. each headlight has its own fuse. I believe #4 fuse under hood is for passenger side low beam. fuses 1-4 under hood are for the four headlights as I understand the info I have seen.
2007 lacrosse low beams out
Headlight module ! You can get one at a buick dealer for about 40 buck. Good luck!
After replacing the drivers side headlight assembly on a 2006 buick Lacrosse, the high beam hits the road very low. Is there an adjustment I've missed?
If they are adjustable, the adjuster screw would be visible just above or below the lens. Are you sure the bulb is seated in the socket? and seated into the light assembly squarely?
Replace headlight on 2006 buick lacrosse
how do you remove r/h headlight assembly 2006 lacrosse to install low beam bulb?
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
