I replaced the motor control board and I'm not sure exactly where some of the wires plug in I have green and yellow earth wire and one ground which comes off the board both with mail plugs on each wire anda single green wire which splits in two one with a black plastic flat plug female and one with a flat silver metal one female which comes from a group of coloured wires taped together Then a plain green wire flat metal male plug comes from behind machine and another green yellow wire white plastics female plug comes out the same place the phase and neutral plug does I then have one male plug left on board which says 230. 4a and 120v 6.3a I not which to plug into which
SOURCE: used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
SOURCE: l need the wiring diagram
I was unable to find your model but maybe there are some other clues to the model's number you can use on this web site.
http://www.geappliances.com/service_and_support/literature/
Also all washing machines include a wiring diagram underneath the control panel at the top. Unscrew from behind and the sides and remove, be careful of the wiring. You don't want to pull a connection out.
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
