I recently order a new power supply board from 'shop jimmy', and while not an experienced tv repair guy, I checked all the numbers and parts on the board. I went to unscrew the old one and put this one on, when I realized there's a pin connector cable that goes from a 20 pin on the main board to a 16 pin on the power supply. On this new board that jimmy sent, it has a 14 pin connection. I don't solder, so can I get a connector cable somewhere that's 20 pin to 14 pin that will work? Or do I need to somehow get a 16 pin female connection on the new board
SOURCE: we have samsung LCD with
So the standby 5vdc is working but not the rest of the power supply outputs are working? Look for PS_ON signal (3.3~5vdc for ON) from the main board that feed the power supply board. You can tak ethe power supply moudule out the do bench test using 24v lamp attach to the 24vdc out put and feed the PS_ON with 3.3v to see if the 24vdc will turn on.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
I have a feeling that the main board is damaged since the protection Diodes are blown, it may have taken out the processor.
SOURCE: IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
SOURCE: no pic sound works
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Testimonial: "replaced power supply board smps did not work think it the led back light burnt out."
SOURCE: Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Testimonial: "I have already replaced T-con board. here is what happens. initial tv had blank screen , with audio. and back light on. so I ordered T-con board and replaced it but now with new T-con board connected backlight is flickering like a strobe light. and I have tried with 2 different lvds cables. same result of flickering."
