Nabi 2 Logo
c
christy Posted on Feb 11, 2016
Blinking on and off during play time and it is charged completely and updated??
1helpful
How do I determine if I need to update my Kindle Fire?
Your Kindle Fire needs to be fully charged and connected to a Wi-Fi network before you can download the software update.
Tap the Quick Settings icon, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update.
3answers
Do I need the updates on this kindle
If the kindle is functioning how you'd like it to, there is no requirement to update your kindle.
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
I charged my 7" sound logic XT tablet, but its stuck on the "_android" screen HEEELLLLPPPP
You may have to do a hard reset.hold power button until tablet switches off....then hold power button together with volume up for at least ten seconds, android logo boots to robot with red triangle.leave it alone until it gives you a menu with options to reset.you will lose all you apps etc but once you sign in to google play you will be able to reinstall all purchases for free.once you have it up and running look for google play updates and chose do not install updates let me choose.this is because if you get a partial update or partial install you will crash the tablet again and again.updates come in the background and you should only update when the tablet is fully charged or connected to charger and never switch one off during installations.hope this helps please vote thankyou.
1helpful
3answers
Nexus 7 tablet flashing white light
I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
Tablet slow to charge, won't hold charge
Hi Michelle Y, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
what is the make and OS it is running..and how long have u been having issuses..like it just started or has it been acting up over some time..
Ill follow this
Chadman
1helpful
3answers
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
2helpful
2answers
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Top Nabi Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
techy
Level 1 Expert
Ari Garcia
Ari Garcia
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
