Samsung Galaxy Core Prime (Metro PCS): Home button not working right:
Hello.. If you're HOME button on your phone is lagging or having issues..
Try turning off Samsung S Voice..
1. tap twice the HOME button, so that S Voice comes up.. or go to Apps, select S Voice
2. tap the (menu key) left button next to your HOME button, select settings
3. Uncheck the "Launch S Voice" option
samsunggalaxys3(HOMEBUTTONLAGFIX).mp4
i utilized http://www.safeunlockcode.com and got my unlock code in less than 15 min from my order. Worked perfectly first time round.
SOURCE: My Samsung Galaxy core prime won't connect to internet gives error code
What is the Error Code?
Usual causes of Internet Disconnection:
1. System is Cluttered by junk files, cache files and other unnecessary files.
2. More client-applications installed that needs server connection
3. Block by your own firewall application
Resolution:
1. Clear History Files, Cache Files, Cookies and Junk Files. You can use CCleaner Application or Advanced SystemCare Application for Mobile to clear History Files, Cache Files, Cookies and Junk Files and even optimize your mobile performance.
2. Temporarily remove client-applications installed that needs server connection.
3. Disable your own Firewall Application temporarily
4. Refresh Network connection by Disabling and Enabling it.
5. If you are connected to a Router, restart your Router if not, reset it.
These might help you.
Thanks.
NAD818
SOURCE: How to root Samsung Galaxy core prime?
Refer to the attached link http://forum.xda-developers.com/android/development/guide-root-samsung-galaxy-core-prime-t3032893
SOURCE: How to unlock samsung galaxy core prime to use on any network
What networks it can use when unlocked depends on how the phone was built. There is CDMA and GSM. Go to your carrier store, or the carrier you would like to use, and they can help you figure it out from here.
If you are trying to use the Samsung Smart Switch utility app to copy your contacts, files, photos, phone log, and text messages, etc from an iPhone to your new Samsung Galaxy Core Prime..
..and in the process it says it can't do it..
could it be that the iPhone you are trying to transfer has iOS9?
On the Google Play Store description for Samsung Smart Switch, it says that the software is incompatible with iOS9, but is okay to use with all others iOS 4.21 or higher (link for reference)
https://play.google.com/store/apps/details?id=com.sec.android.easyMover&hl=en_GB
Example using Samsung Smart Switch with an iPhone to Samsung Galaxy S5
Transfer content from your iPhone to Galaxy S5 CNET
*Note: if you had a bright idea to try to downgrade back to iOS 8.4, and create a backup copy of your data in iOS 9.. that iOS 9 backup won't be compatible trying to put it onto your new freshly downgraded iPhone with iOS 8.4.. so I wouldn't try that (link for reference)
http://www.imore.com/how-downgrade-ios-9-back-ios-84
On Samsung's Smart Switch official website, it says that if you use a OTG cable to make the switch between a computer to your new Samsung Galaxy phone it will work with iOS 9 (link for reference)
http://www.samsung.com/us/smart-switch/
See Samsung's help instructions on how to transfer from iOS 9 to your Samsung Galaxy phone via OTG cable here:
http://www.samsung.com/us/support/smart-switch-support/app/partial/howto/htg.html
(Note: as of this writing the images at the above webpage may not be visible. i alerted Samsung to fix this)
>> If this was helpful in any way, please let me know so that I will continue helping others, by Clicking on the Helpful button below. Thank you :)
