The repair person said all the hot water was being used for coffee and it could not be changed. It worked fine before the solenoid was replaced.
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
SOURCE: MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
SOURCE: I have the 5 place warmer Bunn auto coffee maker.
Check the big fitting on the back of the brewer, there is a micro filter in there, that might be blocked, if not then check the solenoid behind the front panel. Easiest way to make sure tank is full is to pour water in through the manual fill and let it flow out the sprayhead.
SOURCE: I have a Bunn NHB
If you will call customer service at 800-352-2866 with the model and date code, we will be happy to assist you with this issue.
SOURCE: leak from hot water faucet
Replace the TERMOIL O-Ring part n. 140328561. Look for the diagram Cod. 10000071-114-220-502 a pdf available on the net
