I have a Merits scooter Pioneer III 3wheeled scooter and my 4 way flashers & signal lights stopped working. I want to replace whatever needs to be replaced if I knew where to find it...
You can call Tech support at Merits 800-963-7487. owners manual may have where the fuses would be. Lights could be burnt out. more likely the wires were disconnected.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: will not go. ohm wiring
me tool time you checked or changed about everything but did you check the electric brake. Sounds like the brake is not working or is working intermittentaly. The controller needs to get the right reading from the brake or the scooter will not go and when you release the throttle the brake should engage immediately. I can't give you a well thats the answer but you should at least ohm out the brake. If you can call rascal Company on Monday and ask for tech support they can give you what the reading should be Hope this helps
