Question about Panasonic Televison & Video
Where to source replacement power button? The power button on my Panasonic TX-21S3T has broken. Sadly the Panasonic spares site lists it as obsolete ( http://www.4panasonic.co.uk/cgi-bin/product.pl?PID=827056&query=Panasonic%20TX21S3T&model=TX21S3T&path=112610 ). Any suggestions where I can get another one in the UK? Thanks, Ewan
  • 4,234 Answers
I don't have a listing for that model as I can only see US models, but many of the Panasonic models of that vintage use generically available power switches. If you can remove the existing switch, check with a local electronics parts supplier. They may be able to match one for you.
Dan
Posted on Jul 16, 2009
  • Demonic-2011
    Demonic-2011 Feb 17, 2011
    The trouble with simple parts such as the on/off switch, especially the standard PCB mounted types, is they become obsolete before time, making them difficult to get.
    Best option is to remove the original switch (with TV unplugged from wall) examine it, take it to an electronics store and see about a generic replacement with the same pin orientation. I have had the same trouble obtaining original genuine parts for TVs of any brand/vintage.
SOURCE:
How can i turn on my panasonic tx-56p8ooh tv without a remote control
You should have a remote control to power it ON. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
Jul 31, 2018 | Panasonic Televison & Video
Panasonic Vierra model number TX-37LZD81. It won't turn on at all
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 26, 2016 | Panasonic Televison & Video
Any one know where i can source suffolk punch parts.
Hi try these sites www.ransomspares.co.uk. . www.mtmc.co.uk. . www,raidiy.co.uk..,.,.< discontinued spares <. good luck
Jul 29, 2016 | Garden
To bring up source list I tried the remote and the button on side of tv but source list flashes only for a second then disappears. Therefore I cannot watch tv. What should I do about this problem?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 11, 2016 | Televison & Video
I have a Panasonic TX-48CX400B and can't find the pip button how do I get split screen off tv.
The PIP mode is only used to show the current source if you are also looking at the Internet portal mode. After you set up your network connection, press the Internet button on the remote to access the network options. (That's the button with the globe and an arrow that curves up from the bottom right of the globe.) Press OK to select an internet option.
See page 28 of the manual for more information. (I found the manual for the TX-48CX400E here, http://www.panasonic.com/uk/support.html , and looking through the list of LCD TV models. Then click on the Downloads link and then choose the version of the manual you want. From here, you need to accept the Panasonic terms of use for their downloads. The direct link to the manual is http://tda.panasonic-europe-service.com/docs/2z56564c5ez3z3bebbz656ez706466z23zba9e6b6cadec0298b6a49aa5ad340d60c1bb0f19/pgrp001/pcat033/tx48cx400e/933026/BG1WLCAKK3RR.pdf . This is the same model sold in another country.)
I hope this helps.
Nov 25, 2015 | Panasonic Televison & Video
Cannot control oven temp.
SADLY this does happen and when it does all that can be done is scrap it out and replace with a new unit .
Sep 19, 2015 | Ovens
Panasonic Viera TH-42PD60X Plasma TV not power up at all
Jan 21, 2012 | Panasonic VIERA Televison & Video
Hi, my Panasonic TX L37G10 B (6 montha old) has developed an annoying fault. When watching it, the screen will go off (accompanied by a clicking sound) then the green light will flicker until it comes back...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2017 | Panasonic Televison & Video
VOLTAGE REGULATOR STR-M6529 FAILED , SOURCE REPLACEMENT
Hello
For spare part availability, you just contact E-Bay by mail. They have most of the spare components and is a trusted firm. The part you need will be delivered at your doorstep. Send the details of your requirements, and all other about your Tv. They have the facility to find out the part. OK.
Dec 20, 2010 | Panasonic TX-29S90X TV
Broken screen
Parts Dist Cititronics / Panason St Louis Mo
1 800 846 2484.
please give me a rating for this info.
thanks
daniel.
Jan 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
237 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
