I can order the part, but I can't figure out how to separate the bearing retainer from the bearing and the retainer (all parts 21, 22 and 23 on an exploded view). Do you pry the bearing retainer and the retainer apart? Do you try to pop out the bearing from the center? And if so how do you do that?I can order the part, but I can't figure out how to separate the bearing retainer from the bearing and the retainer (all parts 21, 22 and 23 on an exploded view). Do you pry the bearing retainer and the retainer apart? Do you try to pop out the bearing from the center? And if so how do you do that?
The bearing is going to be pressed in. You will have to make a jig that allows you to hit it out with a hammer from above.The bearing is going to be pressed in. You will have to make a jig that allows you to hit it out with a hammer from above.
Thanks all. I put it in a vise then popped it out by using a socket (socket wrench) and hitting it with a hammer. No special tool. Yippee!Thanks all. I put it in a vise then popped it out by using a socket (socket wrench) and hitting it with a hammer. No special tool. Yippee!
You can't post conmments that contain an email address.
Actually I was able to get it out. No bearing puller tool needed. Just needed to pry the top and bottom pieces apart and then punch out the bearing using a socket piece and a hammer. Popped right out.Actually I was able to get it out. No bearing puller tool needed. Just needed to pry the top and bottom pieces apart and then punch out the bearing using a socket piece and a hammer. Popped right out.
LOOSEN the the bolts that clamp the fork legs to the tree. Remove the fork legs along with the front wheel by pulling down on them. Be careful that the brake hoses and the speedometer aren't damaged. Remove the center nut. Bend the lock washer tang so that the bearing retainer nut can be removed and remove the nut and washer from the center shaft. the tree should slide out from the bottom. Don't remove the bearings from the center shaft unless you are going to replace them. When re-installing the center shaft, tighten the bearing retainer nut just enough so the shaft doesn't shake but not so tight that there is a bind when turning the tree. this can be re-adjusted after all assembly is complete.
Good Luck
If the threads are strippedon the bolt, you will have to get a new bolt or retap the threads on the retainer, if the holder is stripped, or replace them both
Which bearing? The hub bearing? I can send it. I have your Ford shop manual & wiring books for $25, plus $4 shipping. Let me know.
SECTION 205-01: Driveshaft
2002 Lincoln LS Workshop Manual
DISASSEMBLY AND ASSEMBLY
Driveshaft Center Bearing
Special Tool(s)
2-Jaw Puller 205-D026 (D80L-1002-L) or Equivalent
Puller, Bearing 205-D064 (D84L-1123-A) or Equivalent
Driveshaft Alignment Bushing Remover Tube 205-D073 or Equivalent Disassembly
Remove the driveshaft (4602). For additional information, refer to Driveshaft in this section.
Separate the front and rear shaft assemblies.
CAUTION: Do not clamp on the driveshaft tube as a fracture can result. Position and clamp the driveshaft at the weld yoke.
Using the special tools, remove the retaining ring and the center bearing and bracket assembly (4A499).
Assembly
Position the center bearing and bracket assembly and the retaining ring on the yoke.
Using the special tool, drive the retaining ring and bearing assembly until fully seated on the yoke.
CAUTION: Align the index marks or driveshaft imbalance can occur. Assemble the front and rear shaft assemblies.
Install the driveshaft. For additional information, refer to Driveshaft in this section.
1 Jack the front of the vehicle up and support with jack stands. Remove the front tires and the front brake calipers. Hang the calipers up or support them so they are not hanging by the brake hose, which could damage the hose.
2 Remove the caliper support, then remove the center bearing cover using the hammer and chisel. Tap it out easily so as not to bend it. Remove the cotter pin in the spindle.
3 Remove the large bearing retaining nut and grab the rotor with your hand and rock it forward just enough for the front bearing to fall out.
4 Put the large bearing retaining nut back on, but do not turn more than four or five threads. Grab the rotor with both hands at the 3 o'clock and the 9 o'clock position and pushing down slightly, pull the rotor off swiftly. This will remove the rear bearing and seal at the same time. The retaining nut will knock the bearing and seal out as you pull the rotor off. Remove the retaining nut.
5 Remove the inner races for the bearings using the hammer and chisel. Put the chisel on the top of the bearing race and hammer it down toward the floor and then turn the rotor over and do the other side the same way.
6 Install the new bearing races using the old races as a buffer or an installing tool. Lay the new race in the rotor and line it up to the recession and lay the old race upside down on the new one. Hit the old bearing with the hammer to drive the new bearing into the recess. Make sure you drive the new bearing all the way into its recess. Do the same for the other side.
7 Fill the palm of your hand with grease and push one bearing at a time into the grease and drag it across the hand so that the bearings get a full packing of grease. Install the large bearing first by dropping the bearing into it's race and then installing the seal with the hammer.
8 Install the rotor back onto spindle and hold it in place. While holding the rotor on the spindle with one hand install the front small wheel bearing followed by the large washer and the retaining nut. Tighten the retaining nut (use the crescent wrench) just enough so that there is no play felt. Tighten the nut another 90 degrees with the wrench and then rotate the rotor a couple of times. Back the nut off until it is loose then tighten just until you feel the friction of it tightening up again and stop right there. The bearing must be tight enough that there is no freeplay, but not so tight that the bearings will seize up when they heat up and expand.
9 Install the cotter pin and the bearing cup. Install the caliper support and the caliper. Do the other side the same way then install the tires.
Remove 2 center bearing retaining bolts and remove the center bearing and driveshaft assembly.
Check the center bearing for wear or rough action by rotating the inner race while holding the outer race. If wear or roughness is evident, replace the center bearing assembly. Examine the rubber cushion for evidence of hardening, cracking, or deterioration. Replace as required.
To install:
Place the bearing in the rubber support and the rubber support in the universal shaped support, if removed.
Install the center bearing and drive shaft assembly. While supporting the center bearing in position, install 2 retaining bolts and tighten to 39-53 ft. lbs. (53-72 Nm).
Road test the vehicle and check for proper operation.
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
Raise and support the vehicle safely.
Remove the wheels.
Remove the brake drum or brake disc.
Remove the hub grease cap.
Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
Remove the outer bearing and cone assembly.
Remove the rear hub from rear wheel spindle.
Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
Remove the inner bearing cone and roller assembly.
Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
Install the hub assembly on the spindle.
Install the outer bearing cone and roller assembly on the spindle.
Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
Remove the caliper from the spindle and rotor, but do not
disconnect the brake hose. Suspend the caliper inside the fender
housing with a length of wire. Do not let the caliper hang by the brake
hose.
Remove the grease cap from the hub and remove the cotter pin, nut retainer and adjusting nut.
Grasp the hub/rotor assembly and pull it out far enough to loosen
the washer and outer wheel bearing. Push the hub/rotor assembly back
onto the spindle and remove the washer and outer wheel bearing.
Remove the hub/rotor assembly from the spindle.
Inspect the rotor for scoring and wear. Replace or machine as
necessary. If machining, observe the minimum thickness specification.
If the rotor is being replaced, remove the protective coating
from the new rotor with brake cleaner. Pack a new set of bearings with
high-temperature wheel bearing grease and install the inner roller
bearing in the inner cup. Pack grease lightly between the lips of a new
seal and install the seal, using a seal installer.
If the original rotor is being installed, make sure the grease in
the hub is clean and adequate, the inner bearing and grease seal are
lubricated and in good condition, and the rotor braking surfaces are
clean.
Install the hub/rotor assembly on the spindle. Keep the assembly
centered on the spindle to prevent damage to the grease seal or spindle
threads.
Install the outer wheel bearing, washer and adjusting nut.
Adjust the wheel bearings according to the procedure in
, then install the nut retainer, cotter pin and grease cap.
...or do you order all three parts already together?
