Winter Sports Logo
Lane Reas Posted on Feb 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 Polaris 500 Classic with electric start and reverse. What caused electric start to fail?
Angelo Stewart
Level 2:
Champion:
  • Expert 224 Answers
  • Posted on Feb 10, 2016
Angelo Stewart
Expert
Level 2:
Champion:
Answers
224
Questions
0
Helped
106323
Points
331
Starter solenoids have the tendency to just stop working. Yamaha is notorious for going through the more frequently than any other manufacturer.
2000 Polaris Scrambler 500 4x4 ATV won't start? Good battery and no lights with key.
5 years standing is a long time. Carburetor float will be stuck. Pull the plugs and see if they are wet and also if you have a spark.
Strip and clean carb and jets.
Check fuel tap and fuel delivery.
Drain any fuel and replace with new.
Replace the spark plug.
No lights is odd. Check if there are fuses?
Manual
https://www.google.com/search?q=2000+polaris+scrambler+500+service+manual+pdf
Parts and Parts Schematics
https://www.polarispartshouse.com/oemparts/l/pol/50343730f870023468a741cc/2000-scrambler-500-a00bg50aa-parts
Jul 01, 2021 • Polaris ATV
Have a 2000 polaris scrambler 500 and only backfires and pops in reverse. drive has full powrer and starts great
your reverse over ride not working , u need to open switch box see if you have power to the switch when bike is running with a test light then with brake on and in reverse check the output wire to see if you have power out when depressed be sure you have the wheels up in the air when you do this for safety sake
Dec 31, 2016 • Polaris ATV
We went to look at a Polaris 500, it's a 2000, and only has 536 miles on it. When we finally got it started the lady parked it in reverse and it won't shift back out of reverse? Any ideas? Help?
try to remove the positive cable from the battery and switch on all lights,headlights ,park lights,step on the brake pedals , switch on ignition but do not start it. this is just to drain all remain electricity. then after doing so, switch off all the above mention lights and ignition. install back the positive cable to the battery. step on brakes pedal and start your engine,now try to shift gears from reverse to N then to P .
Polaris 2003 600 classic perc rverse problem
my 2003 polaris 550 indy's reverse doesn't work maybe once in a great while it will work but like tonight i rode for about 1 hour and tried to put it in reverse and it didnt work it died down and stalled out then started it back up and tried it again and it went forward i need help and information
Polaris classic 1997 500 when warm out loads up . run down trail at about 20mph feathering gas at about 3/4 then after awhile well clear out and the next time slow down start all over again . this is only...
Easiest first, put dry gas in and run it if that don't work, try draining gas, take tank off, drain carbs. You may have water in tank. If not next best thing is try changing the coil. If it backfires it is electrical.
2answers
I have a 2000 Sportsman 500 RSE. I dont seem to be able to shift into reverse. The shifter moves freely from Neutral, to Hi or Lo, and the Neutral Green indicator light will light as expected, but the...
remember on early models there was a safety pin that had to be held to switch to reverse,,,your 500 does this automatically so check for safety pin hookup. Could be brush or
grass jammed in where it moves.
Dec 25, 2017 • Polaris ATV
Top Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Winter Sport Expert? Answer questions, earn points and help others
