Air Tools & Compressors Logo
Darel Carnegie Posted on Feb 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Feb 09, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061476
Points
28436
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
1helpful
I can not get the plow to go up. Motor does run, does turn left and right
Excessive oil at the lift ram top seal? Piston seal is gone. No excessive oil at top seal, probably O rings in control valve.
Engin oil burnning
if its a 4 stroke engine then you have piston ring or valve seal or head gasket problem ! compression test 100 psi or more ! remove exhaust and pressure test piston and put some oil in exhaust port on valves with piston at top dead centre and look for bubbles and air leaking past valves , and listen for air passing into crank case which tells you if rings are leaking ( put oil on top of piston to cover the top ring the second time you test this to see if better seal on rings ) !
F28WW-fire gun. piston doesn't retract back, trigger is good gun is clean & oiled what could be the problem. nailer year old
Check band # 175520 (black rubber band around the outside of the cylinder) is what causes the piston to retract. If the check band is in place, then problem could be caused by cracked lower bumper, worn piston oring or cylinder seal on the headvalve. IF the cylinder seal is bad, air will leak between seal and the top of the cylinder and could push piston down cylinder. If piston oring is too loose, the piston will not stay at the top of the cylinder. If you point the nose of the gun up then down again and the driver moves within the cylinder, replace the oring. Good luck
I just put a repair kit in my sx150 stapler and it fires put will not recoil i think im missing a spring in the bottom of the piston cylinder?
The Bostitch SX150 pneumatic brad nailer/stapler uses air to both drive the brad or staple and to return the driver/piston assembly to the top of the gun for the next firing. There is no spring that goes into the sleeve or under the piston. If your driver is not returning to the top of the gun you may have put an o-ring or seal in the wrong place or left one out. The o-rings and check seal on the bottom half of the driver sleeve are what control the air that returns the piston to the top so check those first.
Paslode 350s .The drive pin will not retract behind the next nail. I replaced all the orings and reassembled the way the pieces were (because of minor wear) With the air at 80 to 100 psi it should be...
Usually there are four things that affect the driver not reaching the top of cylinder. Piston oring too tight or too loose, exhaust air is restricted at top of gun , check valve oring is missing, or air leaking down thru blade seal. Assuming that the piston oring is ok and exhaust is not restricted, make sure that oring # 092235 is in place covering the small holes on the outer lower portion of the cylinder. this is the check valve that causes piston to come up. If, however, too much air leaks down past the blade seal, the driver will not make it to the top. Blade seal is a metal washer with slit just large enough to pass the driver blade. If worn, just make a washer out of tire tube and make a small cut with sharp blade just large enough to pass the driver blade. Make the washer larger than the metal washer and just place it on top of the metal washer. Put back together and nail away. Good luck
2010 flstc, intermidiate vibration in rear end. Rear breaks. I took calipers off, pumped petal and top piston came out bottom would not. pushed top piston in and held with vise grips. pumped petal and...
Since you've already taken one piston out and got the other one almost out, I'd go ahead and get both out and put new seals in them. Once you get the piston out, you'll probably see why you could not push it back in. It's probably got some corrosion looking stuff we call "shale" on the piston. Now that this mess is between the piston and the seal, it's very tight. Just go ahead and rebuilt the caliper.
Good Luck
Steve
Need only the Piston Seal for McCulloch Woodmate 1 log splitter. Model # 400057B Serial# 11-016227
how do you know you need the piston seal. mine also will not build pressure, I think it is the valve assembly that is under the piston. IF you find parts please let me know source. I do not understand why people above posted about the manual. you clearly are not looking for a manual.
Jan 05, 2011 • Garden
I have a Craftsman 919.165610 2 stage oil free air compressor. It will not build pressure? I have replaced the check valve, checked the filter and still no luck? Help
Problem sounds like valve plate /reed valves or worn cylinder /vinyl ring. Easy to check, push piston to top position and examine cylinder neer top looking for scratches. If scratched, most likely vinyl piston ring/s are worn and allowing pressure to leak past. If cylinders look good /shiney all the way up to top, remove head/s and examine reed plate/s for missing/broken reeds and or torn gasket/s. If your reed plate is missing one reed and your are good at being creative, you can seal individual hole by threading and plugging with thin piece of bolt. Good luck and good holidays
How do you remove the piston from a front master cylinder on a Kawasaki KZ1000 B3 1979 LTD
first you must remove the lever from the master cylinder, then you will see a rubber seal this must be removed, it is not always possible to remove this seal without damage so i would suggest u find a replacment, the outer of the seal can corrode to the master cylinder, once you have removed this you will find a circlip which holds in the piston, remove this keeping a slight pressure on the piston as it is spring loaded, remove carefully so u can ensure correct reassembly of parts, in some occasions the circlip is located on top of the rubber seal.
My driver doesn't come back far enough to pick up the next nail
Many causes for this problem. Some things to check. Push the driver up by hand to see if it moves easily /hard. If hard, check for bent driver or dry cylinder. If it moves easily, check piston oring too worn and /or air could be leaking down past the bumper area. Most guns have very close fitting bumper or a seal below bumper. If too much air leaks down past bumper driver will not return fully. Check seal could be loose or broken. Remove cylinder and look for check seal covering a row of holes on outer/mid to lower part of cylinder. could be a band or oring and should fit rather tight. If ok only other parts to check are the headvalve and piston stop. Piston stop should not have cracks or missing pieces (piston stop slows/stops piston when it returns to top). Head valve should be well lubed. Good luck
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
