The product has two wires coming out of the dimmer. The wall socket has two red wires connected to each other and a single blue wire.
Normally in market, most of the dimmers are 3-way and single pole dimmer, you can use the 3-way dimmer as a regular dimmer, here is the simple instructions with diagram. http://www.bulbspro.com/media/pdf/UTF-8_en_DSL06_Instruction_Sheet.pdf , or you can see Leviton spec sheet http://www.bulbspro.com/media/pdf/UTF-8_en_G-9242_Decora_Dimmer_Spec_Sheet_final.pdf hope it helps
Do you mean a three way dimmer?
How many switches do you want to be in the circuit when you are finished?
A three way switch can be used in a circuit where one or two switches are desired.
What you need to find is which two wires go to the light, and which two come from the power.
Are you in the US, if so, there will be a white wire which should be a non current carrying conductor. It will not be attached to the switch.
Without understanding the number of switches that are currently in the circuit, I'm going to tell you if you just are wanting to replace a single switch with a three way, than "yes" that is not a problem.
Hit me back when you can with the rest of the information.
The product is a Veti 400W two way push button dimmer with a on/off switch. I am in South Africa. The instruction leaflet is vague on which wires to connect. Yes it is a single switch that needs to be replaced. At the moment the single switch is connected to the two red wires in the top connection and the blue one in the other. The ground wire is not connected to the switch.
