Check fuse for gauges. If ok, try banging on top of dash above instrument panel to see if they begin to work again. If they do, possible loose connection or defective cluster
Pull the instrument cluster out of the dash check all the connectors to it for loose pins and also take a look at the printed circuit on the back of the panel, look for any obvious problems. More than likely just pulling the connectors and reinserting them several times may cure this problem.
IF YOUR SPEEDO IS WORKING THEN YOUR VSS IS OKAY, BAD VSS WILL STOP SPEEDO AND USALLY CAUSE HARD SHIFTING. NORMALLY ODO IS CONTROLLED BY SERVO MOTOR WHICH MAY HAVE WENT OUT. CHECK EBAY FOR REPAIR SERVICES OR SIMPLY GET A SALVAGE CLUSTER AND HAVE MILEAGE RESET
Instrument cluster works on & off on my 2000 Ford F-450
