IF A CABLE IS PLUGED INTO HDMI PORT ON TV IT SHOWS THE CABLE IS IN LINE. REMOVE HDMI CABLE IT SHOWS CABLE NOT THERE. WHEN YOU HAVE HDMI CABLE PLUGGED INTO TV AND TIVO OR BLU RAY PLAYER THERE IS NO SIGNAL TO TV.TV WILL WORK WITH ALL OTHER CABLES. JUST NOT WITH HDMI PORTS. PLEASE HELP.
SOURCE: My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
SOURCE: My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Testimonial: "Thanks for the advice but I got it fixed myself, I had the Video Output set wrong."
SOURCE: I continue to have to switch my HDMI cable between
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
