As far as I am aware you will have set the pattern lock.. It's usually a four digit code that you need to input by sliding your finger across a digital pad WITHOUT removing the finger from the pad until you've finished. If you can't remember the code try some possibles, remembering that you probably have a limited number of attempts before itr locks up you could also try settings on the android.
On a tablet you move ahead by swiping the screen with a finger or with a stylus. If and when you use an app the requires text input, a virtual keyboard will pop up on the tablet's screen.
Usually, any Android-based product uses the same process to change the wallpaper. Hold your finger/stylus down on the home screen (with no programs running) and a menu will pop up. One of the options in the menu will be to select a wallpaper and you can go from there...
The Lifebook will never work with a finger or plain stylus touch. It must have an appropriate Wacom Stylus. Various Wacom products will function but the original will fit the screen dock. An available source of an alternative , functional, and reasonable fit in the slot ( a secure fit and allows the lid to close normally ), may be found on eBay - See Item # 140504970431. These units do not require a power source but are interactive. This supplier has a very prompt and reliable service. Good luck. Paul W.
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
