If fluid levels are correct it will be internal problem,have it checked out at a rebuild workshop.
SX 2.4L w/Auto Trans Slip/Jerk Shift Problem - Kia Forum
www.kia-forums.com/kia-forte...td.../55002-sx-2-4l-w-auto-trans.html
Nov 5, 2009 - 10 posts - 8 authors
A noticable rev in RPM between 2nd and 3rd gear only after startup. I had been ... Last edited by TeeJay1959; 11-05-2009 at 04:49 PM. TeeJay1959 is ... Started engine, accelerated out of parking lot and got a rude jerk between 2nd and 3rd gear. You are right .... 1 Attachment(s) 93-02 Kia Sportage Mud.
2nd to 3rd gear shift a "jolting" exoerience
Jan 30, 2015
Please Help with 2006 Spectra Transmission
Jan 31, 2012
2010 Surging while driving
Jul 4, 2011
2005 Kia Spectra Auto Trans Problem
Jun 18, 2005
More results from www.kia-forums.com
Kia Sportage Software Update - RepairPal
SOURCE: Kia Sportage jerking and sputtering
Took it to the Kia dealer they said something was blocked and cleared it.
SOURCE: 2002 kia optima slipping into 3rd and 2nd gear while driving
UPDATE! ! ! Fixed this problem! YES ! ! ! The speed sensors was all that needed replacing. NOT ANY SOLENOIDS ! !. Two of them cost $160 and it solved the problem! Do not buy from the dealers. An after market version is available for $50 each. I was forced to buy dealers.
SOURCE: the engine rpms rev when shifting
Your trans is slipping, u are going to need to have it checked out at a trans shop, they will test drive it in most cases for free and report what they think is wrong or recommend more diagnostic work if they are unsure..
SOURCE: Transmission problem in E230 Benz
What you need to check is the transmission release bearing because if there is a clearance on the release bearing you will encounter this problem and also check the transmission oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
SOURCE: My 2000 kia sportage auto transmission hold light
Did you try to depress the button on the side of the shift lever?
